infloor heating system leaking in concrete
Darrell
Darrell Member Posts: 303
It sounds alot like the Bio-Energy tube. It is black, right? The tubing, as originally conceived, is supposed to push into a punched manifold using a special tool that pushes the insert into the tubing in the manifold, pinching it in place. Yes, you can pressurize individual loops, (and from my experience you should get good at it), by building a tool with either a garden hose fitting or air fitting on one end and a hose barb on the other. The manifolds tend to pinch off the ends of the tubing spilling rusty water everywhere. The tubing tends to erode and go away...pinholes everywhere. The tubing has no oxygen barrier...ongoing corosion issues in system. They may have fixed their product since we used it in the 80's...but it cost us a ton of money, and anxiety. The systems that we managed to save now have new manifolds with push on barbs and plastic auto-motive clamps...you'll have to build your own manifolds. We isolated the tubing from anything ferrous with a heat exchanger and flushed the rust and crud out with Hercules Boiler Cleaner or TSP. Then we got aggressive with inhibitors. Most eventually had to be abandoned and new systems put in.
You can find a leak in the floor by exposing the concrete and laying clear visqueen over it...the leak will show up shortly as vapor on the underside of the visqueen and then you can dig it up and fix it in place. If the job was done right the first time, you can simply pinch off both ends of the failed tube near the manifold and go on without it. There should be enough tubing to heat the space.
  • BK_3
    BK_3 Member Posts: 1
    I have an infloor heating system that has a leak. It was put in in 1989. The hosing is appox. 3/8" with two hoses joined with a web.
    1)How does one install the hoses into the header as they have a one inch plastic insert at the end?
    2) Can each line be pressurized to identify the problem?
    3)What is this system called or what is its brand name?
  • hr
    hr Member Posts: 6,106
    You could be
    on borrowed time with that product. Not uncommon to find those tube plugged with gunk from the rusting ferrous components in the system.
    Any automotice store will have 1/4" barb couplings and those plastic pinch ratchet clamps to fit.
    That tube will slide over 1/4" soft copper tube which I screw into and air nozzle to test and power flush them.
    If the tube splits when you attempt to slide it over tube or couplings, guess what. Start on plan B :)
    hot rod
