strange water problem
ed wallace
Member Posts: 1,613
have a friend who says when taking showers the cold water drops off and she has adjust the hot water to keep from getting scalded she has a symonns valve any ideas this happens when no one else is running the water
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
what's the model ?
Sounds like the balencing spool acting up, may have to replace the stem assy... When doing it so, make sure u flush out the incoming lines!0 -
It may sound obvious
but is there a restriction in the CW line? The Symmons valve is as good as they get with very good factory support.
(I had the opposite problem, HW drop-off followed by falsetto soprano singing and simultaneous orb elevation.)
Turns out my water filter was getting plugged (HW side only) and the Symmons valve was just doing it's job, balancing to pressure and temperature. Crud will do some blocking too as in my case.
If the valve fails to hot I would suspect firstly a cold water blockage then a faulty Symmons valve. But be aware, the Symmons valve is not a true anti-scald valve. If you have scalding temperatures upstream you need a tempering valve anyway or set the temperature lower. The Symmons valve is pressure balanced but turn off one side and what is left on the other will continue to flow albeit less so. Temperature will be the same as enters. Valve can only do so much.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 918 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
