Why pipe indirect 1.25\" if fittings are 1\"?
D107
Member Posts: 1,944
some installers have said, "fitting is only 1 inch; what's the point?"
Also is it standard to install a swing check (or flow check?) and a Hydrotrol on the supply and return of the indirect tank to prevent gravity circulation?
Thanks,
David
Thanks,
David
