Building the boiler (pics)
lchmb
lchmb Member Posts: 2,997
Nice job on the layout Dave! Someone is going to be very happy...Although you can keep that Dr Pepper stuff...ICK
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    new project underway
    Say hello to my little friend....
    This is John my new aprentice, He's raw but very willing to learn, he has good skills and a willimgness to work hard and get the job done,i belive ,with time, schooling and training he will be a very good investment in my company!!
    The job is... two hydro coils , a modine heater and down stairs heating still to be detremind.plus the amtrol boiler mate ( witch i did not surply )but will install....David
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,616
    That second expansion tank by the manifold?
    Dr. Pepper makes 'em? I didn't know that! ;-)
    Retired and loving it.
  • David Sutton_6
    Lchmb...buddy,....pal
    the first step in recovery is admitting you have a problem...there seems to be this deep down inside hatered for a soft drink....could be there was a bad bottle that did you harm while you were a child...or a old girl friend was drinking a fine vintage when she said there was another in her life...lets get together and talk about this!
    ok,, ok,, im ROTFLMAO thank you....David
  • New construction ?
    You lucky dog , Dave . Very nice start to what's going to be a very beautiful install . The new kid's lucky to have a great boss .
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    I must agree
    with lchmb very nice job but if your going to drink get the good stuff Moxie.
    Bruce
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Nice install David.
    I'm a bit worried about the lack of a Pressure differential By-pass valve. If only 1 zone is calling for heat, there may be one **** of a squeal going through those small pipes. (constuctive...I hope, critisism)
    Me thinks it might be a bit easier on, and extend the life of the circulator too. It could also save you the callback for free. Think about it. Chris
  • David Sutton_6
    Very good point Chris
    This i will look into ...thank you....David
  • Ray Landry_2
    Ray Landry_2 Member Posts: 114
    Nice looking job david! One tip for you, you should look into using 'tube talons' for the fostapex versus the emt clips, IMO they are MUCH Faster to put in becasue they already have a nail in the clip, you can just hammer them right up, and I think they allow for a little bit more expansion then a metal clip. What kind of radiation are you supplying? baseboard? Are you going to put in a logomatic?
    Chris, I am a firm believer in pressure bypass valves, but isn't that just a 007 pump? I wouldn't think their would be too much velocity noise if only one zone calls.
  • J.C.A._3
    Surprise Ray!
    With the smaller interior of the pex tubing, I find it a good and relatively cost effective, way of assuring avoiding the noise issue.Primary/secondary works too...but the cost is usually higher...especially now.
    007 pumps move ALOT of water for their size, and more often than not... ARE oversize for typical demands especially with zone valves. (I know what you're thinking...what's the alternative?) A properly adjusted PBDV is the answer. It saves the wear and tear on the poor impeller with little flow...(cavitation, and possibly going over recommended pumping temperatures as the controls are usually located at or in the boiler.) Chris
  • clammy
    clammy Member Posts: 3,212
    Nice job Dave
    Nice job clean and simple nice what boiler is that is it not a buderus g215 or our my eyes shot ,I really don't get many new work mostly either replacements ,updates because of addition and such .Again nice job straigt and clean ,how about another ball valve to completly isolate the whole water feed expansion deal i always hate getting soaked changing a feeder or tank also do you evry have problems with rust from using steel nipples on the water feed ,ran into it quite a few times so for the past 7 or 8 years it's only brass nipples and b&g bras water feeder i know i'm a pia .peace and good lucl clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Leo
    Leo Member Posts: 770
    OK I'm Anal
    Having been a Marine I'm very anal when it comes to little details. That Blue Air Scoop just stuck out to me, awsome. But clean that pipe dope off of it!!!! That's going to be one masterpiece job, great looking soldered joints, my skills went to crap since I rarely install now adays.
    Great Job Dave,
    Leo
  • David Sutton_6
    Yup thats a 215
    The owner did not op for the 2107 ( yet ) so its got the 8148 on there.i use to put a valve before the expantion tank but the valve got left shut once and that was enuff.no problems with the blk fittings. Thanks Clammy !!
  • Joe@buderus_2
    Joe@buderus_2 Member Posts: 302
    Boiler install
    Thanks for sharing the pictures. It is great to see a "newbee" being show craftsmanship and pride in their work. Boiler/system pictures never get boring!!!
