staple up with plates under hardwood
Ed_32
Ed_32 Member Posts: 33
Has anyone had any problems with existing hardwood floors when retrofitting with staple up, any cracking, warping, cupping or excessive gaps? Short of installing a floor surface temperature sensor how can I make sure the temp doesn't exceed a certain setpoint. I plan on using Taco outdoor reset mixing valves, but how do i find what water temp creates the correct floor surface temp?
Thanks, Ed.
