Drop header and Black piping
Plumber7
Member Posts: 19
Because of the "Wall" I installed a steam boiler with steel fittings and piping. And I installed a drop header. The sight of the system was very impressive when it was completed. It took a little longer to install with iron but it was worth it. The drop header is only a few more fittings. The old boiler was piped with the two tees between the two risers like 99% of the boilers are piped in my area. I made sure I explained to the homeowner the value of the drop header so a heating tech doesn't tell them that their boiler is piped wrong because he never saw one piped that way. I should have taken a picture, maybe when I go back in a few days to skim & clean it.
Drop Header
What is the purpose of a drop header? One was installed on the new boiler installed in my building. Thanks.0 -
Drop Header
Drier steam
Due to the piping.0 -
do show us...
I just did one and there are examples in the thread titlrd "steam conundrum" I won't do one any otherway...very slick. I am not sure who came up w/ the idea but....thanks!0 -
Not sure
who came up with the idea , but it was Noel Murdough who first introduced many of us to the practice , here on The Wall . He showed us a pic of a Peerless with a dropped header and explained the benefits of using it in detail .
I've been dropping the headers since then and even though this is just anecdotal , I truly believe it produced drier steam by giving any carryover water one more chance to separate from it before hitting the mains .
Here was my first drop header , April 11 , 2002 .1 -
Drooling
Just looking at that dropped header makes me want a steam system. Is there a case to be made for entirely new steam systems? Inspirational just the same.0 -
Sure there is
much better comfort than scorched-air, just as efficient as hot-water when properly installed and tuned, and they don't have all the pipes and radiators exposed to freezing in a power or fuel failure.
And if you're on Long Island, you can have Ron Jr. and his crew install your new Mega-Steam boiler.
Wonderful
Just by chance .. do you or Ron Jr. or Mad Dog or other great steam proponents travel?0 -
Have steam will travel!
I travel out of my service area for steam system installs if its the right time of year. (summer)There was an error rendering this rich post.
Yes, I'll travel
for steam- where are you located?
Drop header
Ron, this is the picture that I printed out and used for reference for my first drop header job, Thanks. Tom0 -
Travel
Peterborough, Ontario. Bit of a trek maybe. Thanks for all offers.
Just a pie in the sky idea about converting a building.
Have the space and the rads just too many other projects to enjoy/endure in the near future.
I love fixing the old steam systems, but ...
I consider myself to be quite a good steam person. I love being able to make the old steam systems work again, but I would never say what you just said.
You are right about not having a lot of water in pipes that could freeze in the event of an electrical outage, if that happens to be the most important thing to someone, but
A radiant system or even a panel radiator system combined with a gas fired mod/con with a Tekmar outdoor reset control will be much more efficient to run and provide much more comfort to the occupants.
Paul Shay
A Real Good Plumber, Inc.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
The key is
"when properly installed and tuned". No system will run efficiently if not properly installed and tuned.
We're starting to see some of the same results with lo-hi-lo firing on steam as with modulation on hot-water. I had one customer cut his fuel consumption 40% when we hooked up his lo-hi-lo, and I believe one of Terry Tekushan's customers saved over 50%- can't find your post on that, Terry, could you elaborate?
Sure some of the new mod-con hot-water boilers are nice, but if one of them turns around I bet it will see a steamer gaining on it.
Replaced Cast Iron Radiator with Slant Fin Baseboard 1 1/4\". Thi
I took out an upright multi column Cast Iron Radiator & replaced with Slant Fin Baseboard 1 1/4". This is a One Pipe Steam. The baseboard is on the Ist floor above the boiler in the same room as the Thermostat. The Baseboard Spits Water from the Air Vent: Gorton 54 or Hoffman 500 (now 508).
Had same problem with Baseboard on the 2nd Floor directly above. I have a short nipple coming up out of the baseboard with a valve like a Varivalve (it has on the upper part of the valve a perforated ring with holes that you can adjust by sliding the ring around.
What can I do to correct this?
Bring the air vent up higher (how high)?
or
Run a return line back to the boiler?
If so, which is better?
Running a return line from the end of the baseboard by putting a Tee (top of the tee for the air vent & the bottom the tee for the return line) or
putting a Tee in the Steam Supply line feeding the baseboard and running a line from the bottom of the tee back to the boiler?
What size pipe should be the return pipe?
Copper, black, galvanized?
Either
run a return from the baseboard or put the cast-iron radiator back in. One-pipe baseboard doesn't work well unless the length is less than 3 feet or so.
LO-HI-LO
Do they have a LO-HI-LO conversion for residential applications?0 -
old technology
drop headers have been in use for a hundred years just not that popular especially for residential application. saw one in a hundred old church .....two large boilers tied into a common drop header. replaced the boilers & connected into the existing drop headers. jake myron helped lay out the job.0 -
Not yet
as far as I know. C'mon Beckett, Carlin, Riello, Wayne- we're waiting....
