r7184p
Tom Hopkins
Tom Hopkins Member Posts: 554
  • Tom Hopkins
    I installed a new R7184p1072 with the pre & post purge features.I figured I would update the R7184b that I had.Sometimes it works well and then I would come back later and the motor would be running continuosly in the post purge.The burner wouldn't light again with a call for heat until I shut the main switch off and start all over again.I wired it to specs with the additional constant hot wire to the black L1 terminal and the red limit to the limit on the aqua-stat as directed to on the instruction sheet.Fiddling with the DIP switches doesn't help. I was wondering if anyone else has had a problem with this control ?
    Tom P.
