Heating pipe insulation method
D107
D107 Member Posts: 1,944
I'm applying about 50 feet of 1/2" thick Armacel rubber insulation to 3/4" black steel heat and return lines (pipe OD 1.125"). I intend to clean the pipes off first for better adhesion.
1- Can I apply while system is running and pipes are hot?
2- I assume I would place insulation on first, then remove cellophane covering adhesive, then press into place.
3- Any need for tape covering the seams?
4- Should the insulation be placed/stretched around the 90 elbows or should I use the Armacell tape I bought for that? (Tape is much thinner than the insulation.
5- I bought the rubber insulation since it looked like a better insulator, but I did notice that the foam insulation of the same thickness was much much cheaper. Is that usually for cold water lines to prevevnt sweating in summer?
Thanks,
David
  • D107
    got this from armacell site
    "The temperature of the air, of the insulation and of the installation surface must be between 40o F (+4oC) and 100o F (38oC) at the time of installation." That's for the tubolit product; when Armacell distributes to the big box stores I think they change the product name. The 'AP' product I bought seems to be more for cold water than heating lines.
    I also realized I should get the 1" not 1/2" thick insulation if I'm going to bother doing this.
    Thanks,
    David
