Munchie
Al Corelli_2
Al Corelli_2 Member Posts: 395
Did my first replacement of a Munchie (It was a Peerless Pinnacle) blower fan today. Had never replaced on on a boiler that I installed. It was three years old. Only unscheduled service call it ever had.
You all will be happy to know that the new blowers use a METAL fan.
Will post pictures later, camera is out in the car.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=449&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • troy_8
    troy_8 Member Posts: 109
    Munchkin fan
    There is also 100 second post purge available that gets downloaded into the control. A good idea with long flues.
  • Al Corelli_2
    This unit has a short flue. No need for the long purge.
    Here is a pic of the new fan.
  • Ross_7
    Ross_7 Member Posts: 577
    Too cool for school!
    Cool Beans, Al!
    I wonder why HTP didn't do this before when they first started having problems with the fan assembly? Pinnacle has been OK other than that you said?
    Ross
  • Ted_9
    Ted_9 Member Posts: 1,718
    Post Purge
    Even on short runs, I think the longer post purge is beneficial.
    hot_rod Member Posts: 24,507
    longer post purge seems
    to help the flame rod and spark rod life. You need to get that combustion chamber dried out as much as possible after the burner stops.
    Until the day comes when the burners can modulate from 400 BTU/ hr to???? so the components never cycle.
    hot rod
  • Al Corelli_2
    Lots of Munchies
    We have Very many Munchkins and Pinnacles out there.
    The only issues we've had are the occasional flame/spark rod, maybe a pressure sensor once in a while.
    I've replaced blower units before, but this was a first on one of my installs. I rechecked the outside venting terminations to be sure there is no exhaust gas recirculation. This was just time for this blower to go.
    I'm really happy that the new wheel is made of metal. The plastic wheel is made of parts that appear to be glued together. In my opinion, the glued joints cannot take the torque from starting, and failure occurs from stress at these points.
    Again, I have MANY of these units out there, and this was a first for one of my installs. This unit was installed in 2004.
    I would not hesitate to install many more of these, as three of my local supply houses stock all the parts for these units. Plus, I keep a supply of parts IN THE CAR, in a special toolbox, just for these boilers, to handle almost anything that may arise at 2AM.
    I hate when customers are cold.
  • JIM W.
    JIM W. Member Posts: 16
    Hi Al
    Would love to know the name of the supply houses in westchester that stock all those Munchie parts.
    Central plumbing where go has to order them and nobody likes to wait
    TIA James
  • Al Corelli_2
