Buderus 2107 vs Tekmar
Robert O'Brien
Member Posts: 3,584
use an AQ2000 on a rental.The room temp can be limited by the control preventing tampering by tenants
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Buderus vs.Tekmar
I have a 2107 on a B215, three story building no DHW and it works great. I also have a two family rental, four zone system,no dhw, buderus 115. I am weighing adding the 2107 versus a Tekmar 256 for boiler control on this building. I realize I am not talking apples to apples, but is it worth it for me to go the extra $ for the 2107? Of course fuel economy is my primary goal.
Thanks0 -
R2107
I usually like to use the R2107 with a Buderus boiler. But, I suppose if your not doing constant circ. you could just go with the Tekmar. I like both controls.0 -
AQ2000?
Does it do outdoor reset too? Can get the same result with Tekmar, and lock the stats, w/ set perimeters they can do some operation with.
Steve0 -
With the heating issue, I have programable thermostats with the theory that the tenant sets them back during the day(when at work) and at night.If I control the heat I assume I will have to leave the day time at 68 potentially mitigating heat savings?
- 62 Biomass
