Programmable Thermostats for White Rogers Relays?
Dan D.
Member Posts: 1
Does anyone know of any programmable thermostats that are compatable with White Rogers Valve? The valve is Zone-A-Flow Water Valve - type 1311-103.
Using a SPDT relay is the easiest/cheapest thing to do.
W from the stat powers the 24v relay coil.
R from the xfmr goes to C on the relay.
NO on the relay is power to open the valve.
NC on the relay is power to close the valve.0 -
Honeywell Vision Pro 8000
I believe this one can be configured to work with 3 wire WR zone valves.
Mike T.0 -
Honeywell
FocusPro 5000 for non-programmable, or FocusPro 6000 & VisionPro 8000 for programmable will do White Rodgers 3-wire zone valves. Just follow the instructions for wiring and set-up menu changes.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1922ES.pdf
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1920ES.pdf
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1896EF.pdf0
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
