Forced hot water. Temp not getting above 58 degrees
Mark_108
Member Posts: 1
Hello, I have baseboard heat with 2 zones. I just recently changed my thermostats to digital thermostats. I also turned down my furnace to 120 degrees. Everything was fine for a while (about 2-3 weeks). Last night was cold. I turned the heat up to 65 degrees. My temp stayed at 58. It never got hotter even though the heat was turned up. The only thing I can think of is that the furnace temp is too low. Does that make sence? Anything else to check?
that's a good...
start..why did you turnit down so low? temps below 140 are not good for a conventional boiler....kpc
Boiler temp's TOO LOW!
It's a boiler not a furnace BTW; furnaces heat air, boilers heat (or boil, for steam) water, but that's neither here nor there.
120°F is TOO COLD and will cause condensation on the fire side of the boiler, in the flue pipe and chimney -- NOT GOOD -- unless it's a condensing boiler by design -- if not, 140° to 180°F is a good range generally.
Baseboard radiation particularly likes hot (140-180°F) water, (so doesn't benefit as much from a condensing type boiler as say cast iron hot water radiators of in floor radiant) especially at very cold/design temperature conditions (e.g. New England yesterday), otherwise your house will stay cold. Also baseboards collect dust -- you might vacuum/blow them out too.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
