Timkin Silent Heat?
Al Corelli_2
Member Posts: 395
Is this for a Timken rotary?
Or a later Shell head?
I know someone who has a Timken Rotary new in the box. Just have to coerce him to open it to get the info.
I'll check with my Dad. He has books on all that old stuff.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=449&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Looking for info
On a Timkin Silent heat model #OBC205 group#D34A516
anyone?
anyone?
Thanks0 -
No info, but what.......
...are you looking for? I worked on a couple of those Timkens back in the day....0 -
size?
I would like to know the btuh values.
it would help alot.0 -
Gas or oil?
We see a Timkin that's nat gas and uses a power pile valve. Called the silent heat.0 -
Venture over....
To Oil Tech Talk and ask over there.
Alan has a pretty extensive library, and some of the older techs will be able to tell you what you need to hear.
These behemoths were making the big exit as I was coming into the field 23 or so years ago. I worked on a few, but replaced many.I don't think they would run on the "cracked fuel" used today. As I recall, they really liked the old Kero, and worked as advertised...VERY quiet!Alas, all the accoutrement's needed to keep the Rotary burners going are long gone, or gathering dust on a Sid Harvey's shelf somewhere. Good luck. Chris0 -
OBC-205 Timken Rotary
Steam EDR - 850 SQ FT
Water Net - 1,380 SQ FT
From Tom Byrley's Hydronic Rating Handbook Page 358.
Thanks Al and Dale
It is oil. I dont what type it is. It fell victim to a chimney fire over the weekend.
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
