Frequently Asked Questions (Dan H.)
talking about a Hot Surface Igniter which lites the burner. Is the system running? If so have him explain why you need the unit.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,643
    We cover
    many topics here and often go back over the same topic many times ("Can I pipe a steam boiler in copper?" for instance). I'd like to start a Systems FAQ section on the site so we can refer people there as needed. I think it will be a good place to learn.
    This new section will be similar to the Library, Heating Alerts, Green, and other pages on the site that store PDF documents. I'll create the PDFs from Wall posts that do a good job of addressing the FAQ. I'll give credit to the poster, of course. And if you'd like to answer what you think is a FAQ by sending me an e-mail that answers the question, I'd certainly welcome it.
    May I have your thoughts on this idea?
    Thanks.
    Retired and loving it.
    hot_rod Member Posts: 25,323
    How does it differ from tech topics?
    or would some of those move over to the new heading?
    It seems like there is a TON of good info scattered around the site, but few take the time to move around and find it.
    hr
  • DanHolohan
    I get so much out of the Wallies explanations
    of the FAQs that I'd like a place where we can preserve some of these wonderful answers. I can build PDFs from multiples posts within a thread that has to do with a particular topic, and then save those PDFs to this new area. I'll give each PDF a lead-in question, such as, "Can I use copper pipe on my steam boiler?" The answers to those frequently asked questions would all be catagorized by System and the information would be easily accessible.
    Make sense?
  • JohnNY
    JohnNY Member Posts: 3,324
    Great idea.
    I think it's a long time coming.
    Of course, there are lots of FAQs that, I believe, have no stock answer:
    Which boiler should I buy?
    Which programmable thermostat for my one-pipe steam system?
    Can I use copper on my return pipe?
    How much money will a setback thermostat save me?
    Which is better: Oil or gas?
    Does forced air lower the humidity?
    etc.
    But I'm sure you've thought of that.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • DanHolohan
    No stock answers for sure,
    but lots of reasoned thought on each of these has appeared here, and I think I can find a balance as I put together the PDFs. Thanks.
  • David Nadle
    David Nadle Member Posts: 624
    Dont forget...
    Pipe dope or tape or both?
    A faq is a great idea but I agree with the person who said it's already there in the pages accessible from the "Systems" menu, like steam_problems.cfm
    Maybe you can roll those pages up into a wider FAQ section.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Q
    I can think of several related to just one thread on the Wall right now:
    Can instantaneous water heaters be used instead of a boiler?
    If the answer to the first question is yes, can the water heater be used for both heating and domestic hot water?
    Do reflective insulation products work beneath a slab?
    How do I select the proper heating system circulator?
    Why do I need oxygen barrier pex tubing?
    When should primary/secondary piping be used?
    How does flow relate to delta-T?
    How long should radiant floor tubing loops be? Why?
  • scrook_2
    scrook_2 Member Posts: 610
    possible homeowner FAQ questions...
    should I have/use copper vs iron on steam (hot water)
    Should I convert steam to hot water (or hot air, or move south)?
    How do I compare fuel costs between NG, LP/propane, oil, kerosene, electricity, coal, wood, pellets, dried animal dung, biodiesel, waste oil, alcohol, sunshine, wind, district steam, geothermal, uranium, plutonium, unobtainium? (did I miss any)?
    can I convert to a differant fuel? should I?
    Am I short cycling? Is my boiler? How short is short? Why?
    is it a furnace or a boiler anyway?
    how high (low) should my steam (hot water) pressure/temperature be?
    why does my baseboard convector tick/clank?
    why does my baseboard sound like a bubbling brook?
    should I get rid of my radiators and put in baseboard (stapleup)?
    how often/how much should I blow down my LWCO?
    How many BTU per square (linear, cubic, other) foot do I need?
    What pipe insulation should I use
    What kind of x-tank do I (should I) have?
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    Dan:
    If you make the FAQs web pages instead of PDF files, they will be easily searchable by Google, which will help drive traffic and make it easier to find things.
    Steve
    Steve from Denver, CO
  • Great idea as I often
    in posting here have lost bookmarked material, this way some of the great stuff will be preserved for future reference.
    Also I often get asked the same question over and over and have to type or copy and paste from my files. This way there may be some referal of some frequently asked and answered questions.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    That's a great idea, Dan
    anything I can do to help out? I have a BUNCH of bookmarks and links saved up.....
  • gerry gill
    gerry gill Member Posts: 3,078
    probably a good idea,
    as some questions get redundant enough that many times i ignore them, which doesn't help the person asking.
    gwgillplumbingandheating.com
  • Paul Fredricks_4
    Paul Fredricks_4 Member Posts: 8
    FAQs
    I'm not an HVAC person but have gained much knowledge from reading the posts on this board and thank you all for your help with a system I'm contemplating. That being said.... another board I participate in quite often is and engineering topic board where there is a FAQ section. The benefit of this is terrific for a number of reasons. Rather than the more experienced members repeating answers over and over, they can refer the questions (and questioner) to the FAQs (which have become quite well documented over time). The members also take it upon themselves to write answers to FAQs, which can then be added to, altered and tweaked over time. Of course, having a finely tuned search feature is a necessity.
  • D107
    D107 Member Posts: 1,911
    Great Idea Dan
    I think alot of us Wall visitors have been thinking the same thing. There are so many levels of knowledge disseminated here that get buried even with your wonderful search tool. Some things to think about:
    1. How can the FAQ be set up so that visitors will actually use it? The tendency is for everyone to think of their question as unique, and it may be quicker to get an answer from posting than by searching.
    2. How do you divide the fields of knowledge into the large topics from which sublevels of related information flow. Tricky because if you have e.g. separate categories of oil heating and gas heating, there are great distinctions between them but also many areas where basic principles are common.
    3.Perhaps this thread will elicit a few hundred sample questions that will define the shape of the FAQ categories.
    4.There are also wonderful threads on plumbing and electrical.
    5. It would be great if there were some hydronic interns out
    there that could get credit for organizing some of this info. If you have 30 new threads a day that's 11,000 a year X 4? years, maybe 40,000 threads total, 500,000 posts?
    6. Questions I'd like to see addressed:
    a-What things should most installation contracts include?
    b-What things should most oil burner tuneups include?
    c-Why should I hire a Pro to install my boiler when I can buy one myself cheap at the big box stores?
    d-What 10 questions should a prospective installer be able to answer?
    e-what 10 things can HOs do to make the job go smoother.
    7. If you can come up with 10 major topics, then each could be put together by different committees comprised of those with particular interest or expertise.
  • Timco
    Timco Member Posts: 3,040
    Don't forget 'has anybody heard of a beckett heat manager?'
    Tim
  • Darrell
    Darrell Member Posts: 303
    Don't forget my personal favorite...
    How much is a reasonable rate to pay a good servive tech?
    As much as it takes.
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Excellent idea, Dan!
    I usually can do a thread search real quick, but there are occasions where it takes some time to find what I'm looking for. There are many here like Brad, Frank,Hot Rod, etc. whose knowledge would be invaluable for setting this up.
  • DanHolohan
    Thanks for the feedback, guys.
    I'll start building it.
    If you have links that you've saved, either of your own answers or to those that others have offered, and you could send them to me at mailroom@heatinghelp.com that would help a lot. Thanks.
  • Roger Mac
    Roger Mac Member Posts: 1
    Steam Riser
    Dan,
    I have a building in NYC that has one pipe steam. We need to install 3 new steam rads. I would like to run a 2" blk pipe about 40' or so and tie in to the steamm main off of a 2" tapping that also picks up a 1" steam line that goes off into the wall and disappears. The E.D.R. of the rads is 78sqft. It will be pitched properly. This is a one pipe steam system.
    This is the first chat room I found that had your name on it. If I'm not in the right place please redirect me.
    Best Regards,
    RM
  • Kal Row
    Kal Row Member Posts: 1,520
    also product spacific faq's...
    some of us have a lot of experience with certain brands of boilers and their various incarnations and this can be a quick resource –
    but you might have to clear manufacture specific posts with the manufacturer – this may be to much work for a generic site
    the manufactures themselves could contribute – or at least provide a link to their own faq’s – like a 24hr tech support
  • bovide_4
    bovide_4 Member Posts: 161
    classic FAQ's
    How do I clean a steam boiler?
    How do I test a thermocouple?
  • lgiandalia
    lgiandalia Member Posts: 2
    glow plug?
    the gas guy was here and said i needed a glow core plug or glo plug? and that was a common thing that goes bad in heating units.....do i have the spelling right? what exactly is it? i have a natural gas heating unit up in my attic and being just after xmas i would like to have alittle more info before i get quotes on repair...i'm in virginia beach area
  • John_173
    John_173 Member Posts: 63
    Wet wiki!
    With the talent here on the Wall, the possibilities are staggering.
    FAQ's would be a great addition to an already great resource. I search the Wall, but a coherent & inclusive FAQ page would be sweet. Search facility & organization would be critical. Perhaps incorporating some photographs? Do's & don't's?
    And maybe if the FAQ's referred to LAOSH, Pumping Away, etc, you might generate some sales....
  • Daniel_3
    Daniel_3 Member Posts: 543
    I just hit one that could be a start under "short cycling new boiler". It's a toughy for me and even in LAOSH it's not covered to the extent that pertains to the specific problem I'm experiencing, though not really problematic at all. I searched in the tech topics, library, and read througly but haven't found the answer yet.
    I must say that I have been "learned" while here and have delved deeply into the library. Kudos to all and especially Mr. Holohan. I would really enjoy such a source to the more common threads.
    Daniel Bradley
    homeowner in training
  • lgiandalia
    thanx for the info
    thanks for the info yes the unit is running but is not heating the house is that a do it yourself item or is a heating repairman a necessity?
  • A professional should
    do that for you.
  • Dale
    Dale Member Posts: 1,317
    F.A.Q
    Great idea Dan. As a technical trainer I already give the new techs your site. I'm sure other technical instructors do also, I know Timmie does. FAQ will help even more. I guess the next thought is chapt. headings. Hot Water, Steam, Pipefitting, Insulation, Electrical, oil burners, gas burners, ground source heat pump. I hope the answers can be linked to pictures. When I get the "What is a drop header" question I show copies of Steamhead, Ron Jr. job pictures, "How do I pipe a hot water boiler" I show Ron Jr. pictures along with manufacturer drawings.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,895
    I wonder if...
    ... it's possible to link to other sources of info as well? For example; "Tanklets" at waterheaterrescue.com has a lot of FAQs about things relating to DHW.
    Yours, Larry
  • DanHolohan
    I can do that.
    Could you send me a link to the page you have in mind, Larry? Thanks!
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    You can’t do that!
    You can’t start building that without bricks, Dan. I’ll go invest in some right now, oh and by the way thanks for continuously improving on this outstanding community you have built and made available to us. Bless you pal. :)
  • DanHolohan
    Thanks you, my friend.
    You're a good man. Thanks!
  • Leo
    Leo Member Posts: 772
    Another Book
    FAQ would be a nice companion to a "Pocket full of Steam Problems" as well as being on/off The Wall.
    Leo
  • Gerry May_2
    Gerry May_2 Member Posts: 7
    Hi. I'm really new to the Wall, but I have got a treasure chest full of information from Tech Topics.
    I'd Like to suggest that when you are setting up the FAQ, that topics might be arranged in a type of hierarchy so that a search could continue through sub-topics under that particular heading. My point is that it should be easy to get to where you want to go when searching for information. Example: MAin headings could be Steam;Hydronics;Ventilation;Cooling...etc.
    Subtopics could follow under those main headings.Im sure it'll be good.
    ....Just a Thought
  • Randy Schuyler_2
    Randy Schuyler_2 Member Posts: 6
    Dan,
    Larry told me about your FAQ idea and I just read the entire string about it on The Wall. The URL to Tanklets is:
    http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/tanklets-index.html
    I would like to link back to your FAQ page from the Tanklets page when you get it built. It's many times we've sent folks to heatinghelp.com when their questions spilled over into your realm.
    Thank you also for continuing to be an inspiration to us all. A few years ago, you gave me encouragement to keep on trying with my Web site and now it is working well enough that I quit my miserable newspaper editing job a month ago.
    See you at Wetstock in April....
