Dripping steam boiler
Garbear
Garbear Member Posts: 19
There is chemicals that can repair the crack. I don't advise you to do this your self. Sometimes you can create more Problems with using these chemicals. I would call a heating expert to look at it and advise you what to do. I have used chemicals and they do work 90% of the time and last for years. Your boiler is 25 years old If I was you, start saving for a new one. Good luck
  • Jeff_101
    Jeff_101 Member Posts: 12
    Drips in steam boiler
    Hey wetheads. Hopefully, someone can give me some insight here. My steam boiler is dripping water from its bottom inside the fire chamber. I originally heard a few drips of water hitting the gas jets and condensing immediately. Obviously, there is a leak. It only does it for a few drips and as the boiler just begins to make steam. Then, it subsides. How serious a problem is this...or actually, can this be remedied without total replacement of the boiler? The boiler is about 25 years old, but I am not in any financial position to replace her this year. HELP!
