Steam to hot water
bovide_4
Member Posts: 161
A customer wants a steam to hot water conversion. New boiler, three apartments. Wants to convert the existing free standing rads. Must keep it simple, but I see a loop system not working with the free standing rads. What is the preferred piping strategy?
Steam to hot water conversion
Don't do it.
Fix the steam system.
I agree
If you try to convert existing piping or radiators, you run the very big risk of leaks. Major leaks. I've seen where this has happened- it ain't pretty, and usually attracts hordes of lawyers.
Also, the existing radiation may not be big enough to work with hot-water. And a hot-water system can freeze if some tenant leaves a window open, but a steam system won't.
Our company does not recommend or perform this type of conversion, and will not work on a system someone else has converted. I suggest you take the same position.
I agree - I fix many steam systems, and install new steam boilers, following the lessons of Dan's books and Steamhead's posts. I lurk more than I post here, and steam is still the most common form of heating in Brooklyn, NY. The customer wants separate boilers and gas meters, though. And the radiators: leak risk? Haven't had a problem yet, but have not converted many, though. In that case, if we go hot water, I will propose hot water radiators and scrap the idea of converting the rads. I store and reuse steam radiators anyway.0 -
no sweat here
but we also defuncted all the old piping/radiators and ran copper, put in a/c systems with hot water coils, zone valves at the boiler, and where we removed the radiators, we imstalled little fan-assist hot water coils0 -
It might be possible
to run separate steam mains for each apartment, and install three small steam boilers. This approach could eliminate much piping work in the living areas.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
