OT - Unico System
escaseadjug1793177
Member Posts: 22
Do you need to balance just one outlet or lower the flow through all? If it's all you can open the air handler and lower the gate to reduce flow.
Trying to find a place to purchase a unico balancing kit
Off topic here...
I have a Unico high-velocity system in my house and am trying to find a way to purchase UPC-36-15 OUTLET
BALANCING ORIFICE kit. Do you know of any Unico distributors who would order and ship this kit direct to a home-owner? All it is is some plastic plugs with different size holes that slip in the unico outlet so I can reduce some air-flow. Thanks!0 -
beckwithheating
wow.. that is a confusing website!0 -
just a few vents
Just need to balance 2 vents... not adjust the entire system0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
