Water Heater Suggestions Please
Dave_4
Member Posts: 1,405
It was suggested that I should have some well insulated hot water storage capability. I want to take that advice and do this.
I currently have a one pipe steam system, and get the hot water directly from the boiler. The boiler is a 6 year old Burnham V8 with a Beckett oil burner.
Do you suggest an in-direct or something else?
There is no available gas in the house.
Thank you for any suggestions.
bruhl
bruhl
If you have a ....
tankless coil on your boiler you can pipe in a storage tank w/ a bronze 005 and use that as a storage device and the coil as the Heat exchanger....
http://www.htproducts.com/literature/lp-181.pdf
or you can be creative and use an electric water heater as the tank. kpc
Yes, there are things you may be able to do. I recommend only a professional do the job. An indirect wtr htr can be a hot wtr zone, but sizing should be checked. (just like mentioned in the link below)
Here's a start:
http://www.heatinghelp.com/newsletter.cfm?Id=290 -
Oh yes, only a professional will do this job. I stop if something is more than screw-out, screw-in type of thing.
bruhl0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
