burner noise
Norm Harvey
Member Posts: 684
I recently installed the same boiler with a Riello and I think it is quiet. Get the Riellos outside air kit and run some 3inch pvc to the outside for an even more muffled burner fan noise.
burner noise
I am about to install a Buderus G215/3 oil boiler and was wondering what oil burner to use with it? I have heard that the Riello F5 is noisy with this boiler and do not want to spend the extra cash for the Buderus noise muffler. How are the Beckett AFG and Carlin EZ-1. Also should I use a draft damper in the vent piping?0 -
may i say, that is not my experience with three pass boilers.
Riello is a very reliable burner. while i like the 215 i am slightly more enamoured with the Slantfin Eutectic.0 -
burner noise
riello is the most reliable we have installed as far as the barometric damper you should install one these boilers do not like excessive draft buy the muffler noise is do to no chamber material and boiler itself is usaly quite its the noise in the flue havent used any other burners on these boilers worked on a burnham direct vent 3 pass that was very quite but I dont know if they have insulation in the chamber personaly i would like to get the most heat out of the unit so i would not like any type of chamber material0
