underground tank
J.C.A._3
Member Posts: 2,981
New Tank...HEATED space.(If the tank fits...install it!) Resolve yourself and the homeowner of all liability BEFORE it becomes an even bigger problem, and do it tomorrow if possible.
I don't know about where you guys live, but here on the "Gold Coast"...the bankers won't even wright a mortgage for a home with an underground tank...without verification that it has been recently installed...or tested including ground drilling to do "samples" along the oil line path.
Just too much liability there to even warrant NOT replacing it, to either an above ground or basement position.NOT JMHO. Chris
no fuel coming out of supply
christmas eve tech on call is home sick w/e so the boss asks me to look at a boiler customer changed oil filter cannot get it to stay running (he got a delivery earlier that day) 550 ug tank i tried my hand pump nothing tried blowing out line oil bath really bad finally ran a temp line from oil fill did they put check vales on these back in the day and if they did whats next dig up the line or 40 year old tank just install a new basement tank whats the opinion of my peers royboy0 -
New tank.0 -
first. You did right. they have heat.
by drawing off a Known line set at a Known elavation you may have solved the problem for this winter. having it pumped clean would be a good reactionary reply installing a new doublewall UG tank would be the ticket.GL.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
