ANTI-FREEZE
MODERN TECH
Member Posts: 2
Hey thanks alot for your responses.
I know it's toxic but I do not know anyone that has ever drank water from a heating system. Anyway my customer asked me that question because it is cheaper than the hydronic stuff.
ANTI FREEZE
CAN WE USE AUTOMOBILE ANTI FREEZE IN A HOT WATER HEATING SYSTEM? AND WHY.0 -
If you want to destroy your system go ahead
and use automotive anti-freeze. Automotive A/F has silicates which are highly abrasive plus other chemicals designed for the harsher automobile environment.
Automotive A/F is also ethylene glycol which is toxic. Ask your dog. Propylene glycol has a low oral toxicity (it is used in mouthwash and some food products, best not to think about that nor gargle with your hydronic fluid, let's be clear here....
Use Noble No-Burst, Dowtherm SR-1 or any quality propylene glycol made especially for hydronic systems. If you have aluminum components in the system, there are anti-freeze solutions made especially for that.0 -
Not really
as Brad mentioned, the silicates will sludge up your circs and other components. I have seen it happen in a years time.
FYI they do however make non toxic PG automotive antifreeze nowadays. Prestone Sierra, and a few other brands are now standard in many new autos. About time.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
It is not that you would drink the boiler water
but that a spill of something toxic versus something with a low oral toxicity gets less press coverage shall we say...
Yes, automotive A/F does cost less but that alone is not sufficient reason to do or not to do something in my opinion. Straight grain alcohol won't freeze either and it costs even less- again, no one is suggesting you should use it."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
the potential for backflow is always present
If you do use a toxic product in a system be sure it is not connected to a potable water supply or an approved RPZ backflow device is used and tested every year by a certified back flow company.
i have seen bright green fluid flow out of kitchen faucets! happened to a neighbor once when his radiant backflowed into his water system when a fire hydrant down the street was activated.
Use hydronic glycol with the PG and proper addetives to protect us all
hot rod
Disposal Issues
When it goes bad you now have disposal issues. Just because something is cheaper doesn't make it better or right.
Leo0 -
typical heating systems
don't hold that much fluid. At 35- 40% mix you may only need a 5 gallon bucket or so. The price difference, between the correct, safe fluid and a mis-applied fluid seems like a mute point.
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
