Radiator spewing stream of water and steam
We are in a rental and when the heat goes on, one of our radiators spews water and steam from the torpedo-looking thing on top of the radiator. So much so that my husband had to put a towel on the radiator to not drench the floor. What can we do?
  • martin
    martin Member Posts: 144
    Spewing Rad
    It sounds like your system is over filled with water for some reason. Is this radiator on a lower floor. You need to look at your sight-glass on the boiler and look for a waterline, if you can't see one it's probablly full.Get your landlord on the phone so he can grt a pro in there to look at it tomarrow nobody is going to want to come out tues.
