water boiler has 12psi when off, when turned on psi go to thirty
I have a boiler that is set at 12psi, when the boiler starts to heat and when it gets to 170 degrees, the releif valve starts to pop because it gets to 30 psi. I don't understand why the pressure is rising so much. Can someone help understand.
