Oil Line Problem?
Rick W.
Rick W. Member Posts: 30
Got cash oil delivery yesterday - just noticed chilly house; burner tripped off, reset, sputter and off again. Carefully dropped filter housing to check filter condition and it looks decent but cannister had nearly no oil in it. I suppose oil line is plugged or could it be pump failure? Tank is in ground nearby. I will try to blow out line towards tank with air compressor. Any suggestions or SOP would be appreciated. Thanks!
-Rick
  • ed wallace
    ed wallace Member Posts: 1,612
    oil line
    carefull you might have a check valve on the supply line
  • Maine Ken
    Maine Ken Member Posts: 531
    Sounds like you ran out of oil and it needs to be bled. An empty canister is a sure sign of no oil coming from upstream.
  • Rick W.
    Thanks for replies! Blew air back to tank; bit of a heating layman here, did not think of check valve possibilities but heard distinct gurgling out in tank - presume it clear. Will head back down(trap door - old place) to bleed and proceed. Got the wood stove cranking now too - just in case bleeding comes up short.
  • Rick W.
    Oil Line
    Thanks Ed and Ken for input. After bleeding she fired right up. That burner had been running after the oil delivery - how come empty oil canister? Stirred up sludge? I will say, while bleeding, that oil looked quite murky for awhile(three reset cycles). Is that unheard of? Anyhow, the ol' 99FRD rides again!
  • Leo
    Leo Member Posts: 772
    Has it had
    Has it had it's annual service this year? It should be done yearly.
    Leo
  • scrook_2
    scrook_2 Member Posts: 610
    sounds like
    tank was very near empty, filling stirred up the sludge and it temporarily blocked the tank's firematic valve, hence the near empty filter canister & need to prime.
