oil furnace efficiency table?
alecs
alecs Member Posts: 10
Hi,
I was looking for a simple table for calculating oil furnace efficiency based on the difference between ambient and flue gas temperatures. Anyone have a link to this info? I figured there must be a web-based calculator for this but couldn't easily find one.
Thanks.
Alec
  • chris_95
    chris_95 Member Posts: 47
    oil efficiency
    Alec
    Assuming the burner set up correctly, 0 or trace of smoke, stable fire... You'd need to know the net stack temperature and the amount of C02 in the flue gases to calculate the efficiency. Stack temperature alone won't do it.
    Pete
  • scrook_2
    scrook_2 Member Posts: 610
    You'll also need...
    a CO2 (or an O2) percentage measurement of the flue gas at the breech during steady state operation in addition to net stack temperature. Do you have access to an analyser or a Fyrite tester?
  • alecs
    w/ CO2
    Pete,
    Thanks for the reply. Is the table with temperature and CO2 posted anywhere?
    Alec
