T-Stat wiring question
John T_3
Member Posts: 34
I currently have my 750mv boiler and my 24v AC running on the same t-stat (honyewell VisionPro) The steam boiler is on R and W, and the AC is an Rc and the other correct terminals. The jumper is removed form R and Rh. All is working.
Question:
Can I cun the 24v common from my AC to the t-stat to power it? Or will this not work since the R is hooked up to the millivolt. Any thoughts? It works fine on the batteries, but would rather power it from the 24volt if possible.
Thanks!
Question:
Thanks!
will work fine if common comes from AC unit wont work if from boiler
brian
I had a similar issue, Vision Pro stat, air-handler/w heating coil/pump, A/C(in same), DHW tank, toggled with a Taco SR 503, boiler located in out-building with radiant.
Things don`t come to me like they used-to, but I eventually figured-it out(after 3 electricians tried), so don`t feel bad.
These digital stats are not as simple as the "old-lads"!
Dave0
