Panel radiator or fin tube?
kevin coppinger_4
Member Posts: 2,124
good avalability, good product...i have them....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Looking at a project
The homeowner wants a couple of radiant zones to start and a 2 fin tube zones in his basement. Someone a while back mentioned that I could use panel radiators instead of the standard fin tube hot water baseboard. Does anyone have any suggestions for the panel radiators? One of the zones will be in a large game room in the basement that currently has a pool table and foosball table in it. He's planning on adding a wet bar at a later date.
The heat source will be a mod/con boiler. It will have an indirect water heater for the house DHW needs.
The original thoughts were to go with 130° design temps to keep the mod/con at lower temps so that the mix for the radiant zones would be easier.
Thanks.0
- 120 Geothermal
- 394 Solar
