Horizontal Discharge Condenser
Tombig_2
Tombig_2 Member Posts: 231
I'm looking for a manufacturer. A warmboard job has nowhere to locate a four ton condenser for AC ducts except under the back deck. Plenty of airflow there provided it's horizontal discharge. Vertical is out of the question, not enough headroom.
My ducting will allow for staged two ton with four ton max. Variable speed air handler is an option with staged cooling. Any ideas??
Tom Goebig
Goebig Mechanical
  • John Mills_5
    John Mills_5 Member Posts: 952
    Bryant/Carrier
    They have a front discharge in their commercial line so probably not on their residential websites. In fact I couldn't find it on Bryant's dealer site. But they are the only one that survived the 13 SEER shift that I know of.
    Carrier's might be 38HDS model # but their site wasn't working so I couldn't call it up right now.
