Down Feed Convectors Won't Heat
dave_21
Member Posts: 6
if you can, try shutting off all the valves on the other rads and force all the flow through the rads that are not heating
New Boiler Installation And Now The 2 Convectors In Basement Won't Heat. Monoflow System...Down Feeding To Convectors.
Opened Bleeder On Bottom Of Convectors And Got Water.
Finished Basement Ceiling So I Don't Know If They Have To Monoflo Tees Or Not?
Any Suggestions?0 -
New Boiler Installation And Now The 2 Convectors In Basement Won't Heat. Monoflow System...Down Feeding To Convectors. Opened Bleeder On Bottom Of Convectors And Got Water. Finished Basement Ceiling So I Don't Know If They Have Two Monoflo Tees Or Not? Any Suggestions?0 -
monoflow
try increasing the pressure to the max........29 #0
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
