Vacuum pump for filling system
John_53
Member Posts: 3
Hi
I need to fill a radiant under floor system which has ~6000 feet of Wirsbo hepex, all of which is higher than the seven zone manifolds, so there is no way to put a vent at the high point.
I found a related thread here:
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=337533&_#Message337533
Like Greg I have a Schraeder valve for pressure testing, everything holds 60 psi of air for 24 hours. It seems like a no brainer to put a vacuum pump on it and get the air out.
So, has anybody Gregged a Wirsbo installation successfuly? Or unsuccessfully, which is probably more important!
FWIW I plan on isolating the Vitodens 200 and expansion tank, and plugging the 30 PSI relief valve. If the pex fittings hold I think everything else should be OK.
Thanks in advance for any advice or comments,
John
John
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
