Steep Pitch - DF
Dan Foley
Member Posts: 1,268
Brad,
Thank you for the quick response. I will suggest this to the architect. Merry Chistmas! - DF
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=262&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Flashing
I have project where I need to terminate two boilers through a steep (15/12) slate roof. I will be using 3" concentric kits. I am having problems finding a suitable flashing. What do you plumbers do when you have to terminate a vent stack through a steep roof? Any suggestions would be most appreciated. -DF
Cricket
Hi Dan.
Flashing that steep usually has a cricket or tie-in gable from the vertical back to the roof plane. This acts as a wedge to force any run-off and ice to the sides of the vertical projection.
If you see a chimney on such a roof, chances are that they already have something like that to get you an idea.
SMACNA has a publication on architectural sheet metal you may find helpful and the American Institute of Architects (AIA) does also, I believe.
This includes what are often copper or lead-coated copper or terne-plate outer shrouds to conceal plastic vent piping. Many options within those design features."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Several Years
Ago I had to penetrate a slate roof with two plumbing vents. I had a roofing contractor make the penetrations and flash them. I did not want to buy a new roof!0 -
Oatey...
makes a combo galvanized rubber neoprene flashing and they have differing pitches on them. We recently went through a 12/12 roof with a 4" concentric (6-1/2" outer pipe) and they had the flahsings to do the job. It's a stone tile roof, so we have to double up on the flashings.
ME0
