one pipe steam
Ross_7
Member Posts: 577
Hello,
The air vent should always be installed opposite the shut-off valve, and half way up the radiator. This is correct location for the air vent. This should cure your problem(s).Good Luck & tell your heating guy to do some reading & some research.
Ross
Ross
air valve placement
i recently had an old radiator replaced and the plumber put the air valve on the same side of the radiator as the shut off valve.
also, since it's been installed, this radiator has had water hammer. now it also is not getting hot. could the valve placement be the reason for all my problems?0 -
are you sure you have one pipe steam?
Are you sure you have pipe steam? why don't post a pic so we can look at it?0
- 167 Indoor-Air Quality
