Apollo vs Tankless
Had to do something with the State water heater line after they bought it. This is a very in-efficient way to heat not only your building space but your hot water.
Might want check your local building codes also. If the Department of Energy had any clout what so ever these type of systems would be banned.
You have better choices than this, that will cost you more initially but save you more each month.
Under the AO Smith umbrella: AO Smith-
State-
Apollo-
Reliance-
American Water Heater-
GSW/ John Wood-
Maytag
  • Brian A.
    Brian A. Member Posts: 4
    Can I do it?
    My question is can I run an existing Apollo heating system with a tankless hot water system? I was told it needed to be at least 200,000 Btu's, the one I found goes up to 199,000. It is sold At Homedepot. Will I have enough water (hot) in the winter to keep the showers, sinks, dishes, laundry all running (not at the same time) without interruption. I live in Virginia Beach Virginia. Any help would be great. Any direction to get some help would also be helpfull.
    Thanx
    Brian A.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    Is this a direct potable/space heating hot water system?
    One that uses potable water in the space heating system? Or is there a heat exchanger to isolate the two fluids?
    ME
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,858
    Look into...
    ... the AO Smith Vertex heater. It's condensing and may be able to fit your needs.
    Yours, Larry
  • Brian A.
    what
    > Yours,
    > Larry
    I dont know what you mean, is the system I have bad meaning the Appollo. What can I do to make it better or is my only option to get rid of it all together.
    thanks
    BA
  • Brian A.
    What are yoou talking about???
  • Brian A.
    Banned?
    Should my Applllo system be banned is it dangerous or just not efficient?? Is there a way to change the system to a different or would that cost to much.
    BA
