Tuff Stuff around steam pipes?
Janet_3
Member Posts: 18
I have a gap around a steam pipe in my bathroom that I would like to close up because dust and tiny debris falls down through the gap. I put a ring around the pipe, but things just accumulate in the ring. Can I use Tuff Stuff around a steam pipe? The directions on the can say not to use it on a object that gets hotter than 240F. How hot does a steam pipe usually get? I usually heat my house around 68 or 70 degrees, if that matters.
I just want to add that obviously if I end up using Tuff Stuff, I would only do it when the pipe is completely cold, and can stay cold until it cures.
Any and all advice will be much appreciated -
Thanks,
Janet
Thanks,
Janet
Yes
The temperature of the pipe will never exceed 2400 -
Thanks for your answer! I appreciate it.
Janet0
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
