Painting steam pipe
Scottie
Scottie Member Posts: 2
Dear All,
What is this silver paint that I keep seeing on these steam iron pipe? I'm sure my steam pipes are not galvanized, as you can see the paint brush strokes. Is it cold galvanizing paint (zinc rich)? Anything special or am I overanalyzing it? Also is there any advantage to painting the pipe verses leaving it alone?
  • scrook_2
    scrook_2 Member Posts: 610
    metallic paint (probably aluminum). The metal pigment particles tend to reduce the emissivity (heat RADIATION, not conduction or convection --so insulation is still a good thing, especially for steam) from hot objects (like steam or hot water pipes) to cooler objects.
    See also: http://www.heatinghelp.com/pdfs/64.pdf
    As Dan says: "it pays to wander off the wall..."
