Duct Design
Josh_10
Josh_10 Member Posts: 786
Does anyone know of a book for duct design? I don't do duct work but oversee our air conditioning subs. I would like to be able to find potential problems before they happen.
Thanks,
Josh
  • Brad White
    Brad White Member Posts: 2,399
    Josh give me a shout
    I am running out the door but can see what my library holds. SMACNA is a good place to start in the meantime- ASHRAE fundamentals has some material shared with or founded in SMACNA. Check out your local SMACNA chapter.
    I do enough duct design, I can at least steer you.
    Brad
    -Ernie White, my Dad
  • tim smith
    tim smith Member Posts: 2,886
    Echo, Smacna a good choice for reading material
