LAST CHANCE AUCTION $5K Equip for CHEAP!
Empire_2
Member Posts: 2,340
Take it to E-Bay.............. PLease...
Mike T.
Mike T.
Carl Tomberlain Benefit Auction
There is over $5K Trade Cost of equipment offered in thsi auction. CURRENT BID IS ONLY $2400!!
Ken Ebers writes:
We are down to the last day of the Carl Tomberlain Benefit Auction. Keep in mind that all of the equipment listed below has been donated. The full amount of the winning bid will go to "The Carl Tomberlain Benefit Account" to help the wife and two young daughters that Carl left behind.
Thanks to all of you that have placed bids to date. Please e-mail your bids to me at kebers@verizon.net
You are bidding for the following boiler package:
1-Crown TWZ-100 3 Section Cast Iron Wet Base Oil Fired Boiler, 1.00GPH, 120,000 G.O., either with or without Tankless Heater.
1-Carlin Burner for above boiler.
1-Honeywell Programmable Thermostat.
1-Honeywell Boiler Trim Kit consisting of Expansion Tank, Super Vent and Fill Valve/Back Flow Preventer.
1-Hydrolevel Low Water Cutoff.
1-Taco 007F (in addition to the one that comes with the boiler).
1-Taco SR501-EXP Switching Relay.
1-Roth 10001 (275) Double Wall Oil Tank complete with Installation Kit.
1-Williamson/Thermoflo DHW-36 Stainless Steel Indirect Fired Hot Water Heater.
1-Beckett Heat Manager.
12-(twelve) Taco 007 Circulators
1-Set of custom headers built to your specifications by Earth Lee Ltd.
1-Free Delivery by Avco Supply in the Philadelphia Tri-State Area. The delivery charge out of the area will be the responsibility of the winning bidder. A pick up can also be arranged at Crown's Factory.
I will keep you informed by periodic e-mail of the dollar amount of the high bid. The name of the high bidder will not be divulged until the end of the auction on 12/7.
Thanks for all your bids to date! So far, the High Bid is $2,400 Dollars and the auction will end tomorrow (Friday 12/7) at 5pm.
In the event of tie high bids at the end of the auction, those bidders will be asked to submit another bid until a winner is determined.
Sincerely,
Ken Ebers
Crown Boiler Company
Direct donations can be sent to:
Checks should be made out to: "The Carl Tomberlain Benefit Account" Send to: Bob Gussoni c/o Petro 650 Knowles Ave. Southampton, PA 189660
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
