a loud noise is coming from the cylinder and/or hotwater pipes
john_190
john_190 Member Posts: 1
Hi, I have an older oil furnace and the cylinder and hot water pipes in behind the furnace have started making a loud noise over the last couple of days. It sounds alot like the noise you hear inside your house when you are running the hose outside...just a loud water pressure type sound...any advice would be appreciated. Thanks.
  • Timco
    Timco Member Posts: 3,040
    You have a boiler. what does the pressure gauge say? Picture?
    Tim
  • Weezbo
    Weezbo Member Posts: 6,231
    Sound and light give one a clue,...
    if your boiler is turning very red or if you see water on the ground or hissing sounds,..these are not "normal" for any boiler. if the room is very very hot, or humid, this too is not an indicator we would call "Good"....
    really having someone who knows what they are looking at, look at it
    *~/:) would be the ticket.
  • John_191
    John_191 Member Posts: 1
    The Pressure on the boiler says 22.5 psi. I can't take a picture until later tonight.
