Delay in heating
Big Ed
Big Ed Member Posts: 1,117
Are the radiator warm ? What type radiation in the home and what is the temperture of the boiler? Zone valves ? Does the circulator run when a call for heat ?
  • Rob_48
    Rob_48 Member Posts: 1
    Delay in Heating
    The thermostat is set for 70 degrees, but it is reading a room temp of 64 and the boiler is not running. The boiler does not turn on until hours later and runs fine for a while. I replaced the thermostat, but I am still having the same problem. I have called two plumbers and all they do is drain the system. Any idea why there is a delay in heating?
  • Mitch_4
    Mitch_4 Member Posts: 955
    make and model of boiler
    Some controls go into a lockout that auto resets after 5 failed ignition attempts.
    Make and model can help us help you better.
  • Weezbo
    Weezbo Member Posts: 6,231
    it may be a minor Glitch in the control strategy....
    then again there may be some other minor technicalities that need to be addressed.
    sometimes a picture helps....not always is there an easy fix to the glitch.
