Hot water baseboard heat - clanking noise
I have recently purchased a split level 2500sq. ft. home. I installed a high efficiency boiler (Trinity 150) and it works fine. However, when the system is on you hear a clanking noise that seems to be coming from inside the walls. My thought was it's the pipes rubbing against the bottom and top plate...any ideas???
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Thats usually it. Where the pipe comes up into the baseboard you can try putting some rubber gaskets to center the pipe in the hole.
  • Matt_67
    Matt_67 Member Posts: 311
    what kind of clanking?
    creaking and drpipping on inital heat up = pipe touching wood
    jingling clanking( like change in your pocket = air in line
    banging clanking = vibration
    whir,whir,whir = to much vodka
    just my onion.
