Wiring change on Taco relay and triple aquastat ?
Joe Mattiello
Member Posts: 748
Thank you, for bringing this topic up. The change in wiring is to prevent the boiler from firing when the boiler is shutoff using a safety switch. If the ZR/ZR terminals are connected, and the switching relay is using another power source not connected to the safety switch the burner could still fire. For your reference I attached the published safety notice.
Joe Mattiello
Taco Comfort Solutions
I think this started a few months ago ?
When integrating a triple aquastat with a Taco multizone relay , it used to be as simple as connecting a wire from ZR to ZR and ZC to ZC .
Now you have to run ZR of the aquastat to X of the relay , and ZC of the aquastat to the other X of the relay , with a jumper to ZR .
Why the change in wiring ?0
- 167 Indoor-Air Quality
