vent replacement
Dan_43
Member Posts: 58
I have just installed a IN-7 gas fired standing pilot-low water prob boiler. The house is a 1 pipe system. I still have all the old vents on the system. The vents are Hoffman #2 vacuum type. and the mains are Hoffman#16 vacuum vents.
All radiators are getting hot, and the system is quiet. I keep the old pressure gage which reads vacuum. On a cool down cycle I can read (-6 to -8)lbs of pressure (vacuum), the PressureTrol is set at 2 lb /1.5 lb. Is this the most efficient system to operate the new boiler on?
The 2 PSI is a tad high,
and that particular system cries out for a vaporstat.
The new model Honeywell has (I forget the exact model number) would be the match made in heaven, control-wise for you.
Your system is designed to run at one PSI tops! I would suggest getting into the 1-PSI mode ASAP. The existing controller is going to cost fuel-wise - what the correct vaporstat will save in a year or less.
I urge you to make the change while it's straight forward, and little is rusted "tight."
What do you think about the vacuum vents? How do they play into the vaporstat?
Dan0
- 167 Indoor-Air Quality
