Mixing Bio Diesel
radioconnection_2
Member Posts: 70
Sure... Get a tiger loop to get the air bubbles out afterwards.
Mixing Bio Diesel
I've got a friend who makes bio diesel out of old cooking oil. I'm getting 200 gal. to mix with about 600 gal of heating oil. the heating oil is in an underground tank I was thinking of using an air compressor to inject air as I was adding the bio to mix the 2, any other ideas.0 -
not a good plan....
you could very well have problems w/ the mix...oil leaks on the pump and waxing w/ the % blend...b5 and b10 are tops. kpc
Some Friends
of mine had a van that ran on bio-D. The tank with the vege oil had to be pre heated before it could be used.
- 86.7K THE MAIN WALL
- 56 Biomass
- 103 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 936 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
