Ideal Supply & Return Temp for Radiant Under 3 1/4\" QS Oak??
hot_rod
Member Posts: 27,674
that can meet the load and heat the space.
If you have a heatload and design on the system it should provide the temperature requirements. Generally at design (coldest) day.
The Quiktrac design guide will show outputs for that system at various S&R temperatures.
So you can back into the answer or go forward in for the answer.
Is it working now and maintaining a comfortable room tempreature?
A good idea to watch the floor surface temperature. most agree below 85F is a safe number.
Be sure the boiler and the piping is correct to work at those low temperatures. If it is a cast or copper boiler it would need a mixing device and low return protection device, or control.
hot rod
hot rod
Ideal Supply & Return Temps for Radiant Under 3/4\" QS/RS Oak?
Hello Folks -
Can someone please adivse on the ideal water temp at the supply manifold to service my underfloor radiant system? Flooring is 3/4" QS/RS white oak.
5 loops (avg. 225 - 240') of 5/16" pex laid down in quicktrack over advantex subfloor with spray on foam icencne insulation beneath subfloor.
Currently running approx 110 at supply and about 85 on the return.
Many thanks0
- 125 Chimneys & Flues
