Need SEER rating and tons for Lennox model H526-036-3P
John Mills_5
Member Posts: 952
that's a mid 90s Ducane, probably in the 80% AFUE point. The HS26 line ran 12-13 SEER if on the matching indoor coil. Would need to know what exact coil its on to tell for sure.
Where look up age of heat units?
I have a Trane forced air unit model TCU 085B936 B WITH 85,000 output. I want to find the year of manu.,efficiency, have any web sources to find? Dennis Crook0 -
Serial #
May tell us the age. the 36 in the MN says 3 tons0 -
lennox capicity
before 2000 lennox compessor bearing unit
H split
S air cond
26 model
036 gross output compressor my guess it should be 0390 -
Lennox HS26
Lennox HS26 air conditioners were produced Approx 1993 to 2002. SEER ratings ranged from 11 to 14 depending on indoor coil. Serial # will tell the year
Tony B0
