Gas useage report on new boiler
tim smith
Member Posts: 2,841
Changed out old cast iron National boiler w/ Economit F400 burner in >5000 ft 5 unit apt bldg, pre 30s bldg. In Mid september installed new Triangle prestige 175. Got gas bill for full month of october, Gas therm useage down 27% over last year and avg temp was down from 55 degrees for last year to 52 this year. I would estimate then the overall savings was appx 33% over prior year vs old boiler. Just fyi, any further input as to savings calcs. Tim
Don't make the same mistake...
I did.
I incorrectly extrapolated annual savings with real fall savings in the 25% range, only to find the coldest weather reduced fuel savings significantly less than fall. ~5% was the winter savings but 5% of $1,000 a month in winter usage as compared to 25% when the fuel bills were only $300 skews the data significantly!
Moral of the story?
Do not assume fall savings will be annual savings. Annual data is reliable - especially given degree day apple to apple comparison/tweaking. True fuel savings are annual percentages, not seasonal.
fall vs annual
Ken, I understand this, as we get colder savings will dwindle on this system. Although here in Seattle are loads are very moderate and I estimated this system will run condensing temps appx 95% of the time as old cast iron emmitters are well oversized and envelope has been updated some over the years.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
