My Third Dropped Header
Bruce Stevens
Member Posts: 133
Teflon Tape was a firing offense at my shop for years, finally I said fire me and started using it on steam jobs and anywhere I could see the need to pull something apart for a later repair ie extrols water feeds etc and finally the boss caved.
Rye Steamer
Wow,
looks great,,good for you Bruce, I assume the teflon-tape issue is working in your favor?
Again, great job!
Dave0 -
Is that the hartford loop connection right by the fluepipe, under the barametric damper, with the equalizing line comming in at a 45?
It may be an optical illusion but it look a little jigh in that picture.
The piping looks fantastic! Excellent work!
Nice work
is that a Smith 8 series boiler?
Thank you Norm
Actually do to the space limitations there is a gas water heater behind the equalizer line so I piped the header after the last riser over the smoke pipe and went down at a forty five to the Hartford loop takes another forty five just above the tee and drops straight down, I have done it that way many times with no problems. The tee is two inches under the waterline and I thought it was high too until I pulled out the level to double heck myself.0 -
Thank You Frank
and coming from you I consider it the highest of compliments, and yes my boss is totally sold on the Smith 8 series on steam boilers but I keep plugging the Megasteam. When I arrived at this site the boiler was piped with a inch and a half copper header and split to two 2 inch mains via inch and a quarter copper pipe a third split went to one lonely raid on the second floor via one inch copper.0 -
That boiler
can burn gas too- check this out:
http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=51063&mc=4
I know it can do gas
too however in this area we have many accounts that are no where near a natural gas main and I do not see propane as being a viable option in the near future, plus I work for an Oil/Propane Dealer, don't think he will be installing too many NG units but I have done a few including two WM Ultras one at his sisters and one in the office of a steel fabrication plant.
If you want to see impressive the saws that they cut the steel I beams with for bridge girders and buildings looks like a six foot tall table saw blade and just cuts across those beams like butter but at a slower pace.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
