flexible oil piping
lee_7
Member Posts: 457
they are talking about a flexible braided stainless steel line, similiar to flex lines for plumbing. DO NOT INTERMIX. Have they use the proper oil line. Can be found at most supply houses that carry oil parts
I am a homeowner looking to replace my existing steam boiler.
The boiler installation manuals refer to flexible oil piping near the burner swing doors. What is flexible oil piping? Is it soft copper tubing or some type of corrugated tubing I have seen used on gas water heaters?
Thank you.
Jim,
My suspicion is they are referring to the use of soft copper from the rigid oil piping to the burner pump. Typically soft copper is used because it handles the minor vibrations that occur with a rotating piece of machinery.
Tony0 -
If the burner is mounted on a swing door the reference is probably to a flex oil line so the door can be opened for service rather than having to disconnect the oil line each time.0 -
What should I be looking for from the installer so I know it is done right?0 -
Thanks everyone.0
