gas burner efficiency
efficency is to have it set up correctly by a professional gas combustion expert. Things such as O2, Flue temperature, carbon monoxide levels, is the input set correctly, is the unit clean, what is the draft. All of this a real pro will be able to do for you.
So I do not leave you without an answer the typical standing pilot boiler with a vent damper is probably about 65% to 75% AFUE (annual fuel utilization efficiency) combustion efficiency maybe as low as 60% depends on boiler set up and condition.
  • chris_93
    chris_93 Member Posts: 84
    How can I tell what efficency my hydro therm gas boiler is running at. Standard atmospheric burner, with vent damper. If I have someone do it for me, what should I look for.
