Taco RMB tames the beast
hot_rod
hot_rod Member Posts: 26,645
Turns out the mixing block works very well mated to this Aquatherm wood boiler. It gives the owner a precise control for the radiant slab, and with the return boiler sensor keeps the stove in the hottest most efficient temperature range.
A quick easy bolt on installation with Viega fostaPex as the "condiut."
hot rod
